What would the general consensus be in comparing these two products? Which one seems to be less buggy? I like the modern design of both. I listed to a lot of varied genres, everything but nu country. Steve at Sounds Heavenly got the Balance down pretty low on bass. Has he done a video on the A9? If so, I can't find it.
Beosound Balance vs. Beoplay A9
Thanks! I tried to change my original post to make sense. I was asking about the Balance. I dont know how I confused the word Balance with Harmony. My bad. Thanks for noticing and the help.
I am planning to get a Balance to replace an M5. However, in my case I don't think I would replace my A9 with a Balance just because of where I use it in the living room. I find the A9 is very effortless even at high volumes and really good at filling a room. However, from everything I have heard the Balance is also really good and the audio quality is a notch above the BS 2. I believe the Balance is more of a BS 2 competitor vs A9. I was considering the BS 2 or Balance.
You can put the Balance on a table, but you can't do the same with the A9. The A9 looks iconic B&O (IMHO) - if that appeals to you. The BS Edge is another option but slightly more expensive.
Thanks for the replies. I like the Edge, in theory. I, however, doubt its practicality. I don't want something on the floor like that. I don't really want to put it too high up and perpendicular to the wall and lose its features. I don't want to flat mount it on the wall and lose one of the drivers and limit some functionality. It just seems, like, I don't really get the Edge.
People seem to love their A9s.
I really liked the Edge when it came out as I thought it was a bit different looking. However, I do actually agree with much of what you say. It’s not that I don’t get the product but in hindsight, I don’t think B&O properly thought this through, particularly with regard to placement options. It doesn’t seem to have been a good seller and one can’t help but wonder if this is one of the reasons if not the main reason why? I also think it was a little too high; £500 cheaper would have been a more competitive price point in my opinion. It is different, but I suspect many could not accommodate this and make it work with their current home decor. Simon.
Indeed, yet another example of form before functionI really liked the Edge when it came out as I thought it was a bit different looking. However, I do actually agree with much of what you say. It’s not that I don’t get the product but in hindsight, I don’t think B&O properly thought this through, particularly with regard to placement options. It doesn’t seem to have been a good seller and one can’t help but wonder if this is one of the reasons if not the main reason why? I also think it was a little too high; £500 cheaper would have been a more competitive price point in my opinion. It is different, but I suspect many could not accommodate this and make it work with their current home decor. Simon. BV11-46, BV8-32, V1-32, BS2, P6, A1, E8, BR1, Essence
