Beosound A1 3rd generation
New A1 is out. Guess what? It's more expensive.
Looks pretty much identical to the 2nd gen, but it has a different "thingy" on the leather strap (didn't see any article mention this so I'm doing God work here).
Longer battery life, slightly lower bass, different thingy, 5 year warranty and more easily repairable (supposedly)... all for just $100 more than the 2nd generation. I guess that's better deal than the recent price increases that didn't change the product at all.
I will not complain (any more). At least they're still releasing some products I can afford - even if it doesn't seem like a reason to replace my gen2.
You definitely need one, that you can pair with your gen2…….to get gorgeous stereo sound 😂
I actually had 2 gen 2s. A stereo pair of A1s sound far better than they should. I highly recommend!!!
However, I ultimately found the pairing process too fiddly for every day use so I gave my daughter one, and I use the other for conference calls on my computer and for travel. No room for 2 speakers in my travel bag. I still have a gen 1 that I have connected to TV in a small guest house... Maybe when my daughter's A1's battery eventually dies and she comes around asking for my other one, I will go with the gen 3.
To be positive: The new green color seems to look great! Hope they'll release the Explore in the same color, too.
Only technical change seems to be a 3300mah battery instead of 3000mah. But can’t assess what changed on the inside to get a Cradle to Cradle certification for this one. Everything else looks the same according to the productsheets..
out of curiosity, do you know how the beosound a1 sounds compare to the beosound emerge?
It also has a bigger woofer than previous model.
Thanks for posting those product sheets. I was having difficulty finding gen2 information now that it seems to have been scrubbed from B&O's website.
Additional differences I haven't seen mentioned in any articles:
- No more Alexa. I believe Amazon has mostly given up on this as well. Never used this on my Gen2.
- A *fabric* USB cable. Luxury all the way.
- 18 g heavier. Must be the bigger battery.
