Beosound 9000MKIII and MCL2P
hello all,
I need temporarily to connect analogue speakers to my BS9000. I have a spare MCL2P and CX100s plus several types of PL-cables available
If I connect a BL2 to the BS it works fine but the MCL2P and both CXs are mute. If I connect the MCL2P directly to the BS it stops responding to the remote totally
Does BS9000 work with MCL2P at all? If it should work, what I am possibly doing wrong?
Thanks,
tried and found a solution. Not perfect but a workaround anyway. Routing through BL2 does not seem to work at all. If the MCL2P is directly connected to the BS with a MKI cable and BL2 with a separate PL cable I get a working solution.
Mark II cable did not work, though tried it only to connect the MCL2P with CX100s to the BL2.
