BeoSound 9000 Wall Mount Query
I suspect I know the answer to this already, but I'll ask anyway.
Someone is selling the small bracket part (which attaches to the wall) of the system used to horizontally mount a 9000. They are not selling the larger backing plate which attaches to the 9000 however. I have my 9000 on a floor stand. Is it possible to use the backing plate from this with the small bracket I referred to? Or are the backing plates different for each of the (vertical and horizontal) mounting systems?
Thank you
Stuart
I am pretty sure they are different. The wall part has too "claws" that need to be inserted into the backplate and I doubt the stand version has those. I have the vertical wall mount and there are no inserts for the claws from the horizontal mount.
You can get the individual pieces as spare parts though.
agreed, i believe all of the mounts are unique relative to their axis orientation...
Hello,
2054 - horizontal wall bracket, 2063 - vertical wall bracket. These brackets are different, both big plate mounted on the rear panel of hifi and smaller flat hook - mounted onto the wall.
Floor stand has different back-plate
All the brackets come with thier own mounting plates for the BS9000 and wall so if buying used, make sure there are two parts.
Thank you everyone for your replies. As I a suspected, one part without the other is useless - which is probably why it's being sold.
S
