I have a MK 1 Beosound 9000 mounted on the vertical stand. The rear position springs are set correctly for the vertical position of the device. A few years back I had the CD mechanism replaced and playing CD’s was never a problem after that. For several months I have not used the CD at all, only the AUX input.
I recently started to play CD’s again and I have a ticking/rubbing sound coming from the CD mechanism when it plays.
Moving the sled/carriage from CD position 1 to CD position 6 is silent…no rubbing on any of the CD’s as the carriage moves.
It does not occur on all CD’s, but most of them.
If I find a CD that plays without the rubbing sound, it will play in all 6 positions correctly. A CD that makes the noise produces the noise in all 6 CD positions.
All of the CD’s have been in their cases are flat (using a steel ruler), not warped in any way. I wonder if the thickness of a CD could be an issue if an adjustment is just slightly off ?
I am not sure it would make a difference, but when the CD rubbing/ticking noise occurs, I have tried moving the lighted part of the carriage up and down and in and out, but the rubbing/noise does not change.
Can anyone shed some light on this or point me in the right direction to troubleshoot it ?
Could the rocker arm be slightly bent, or would that only cause noise as the carriage/sled moves ?
Thanks for any help or direction.
Mike
