Hello everyone, I thought I had it already some years back but seems I lost it - how can I adjust the startup volume of the Besound 9000, so that its not that loud when starting up?
many thanks, Stefan
many thanks, Stefan
if you use the keypad, select all the settings you want, including volume, and then select ok, then ok again. The settings will be stored for the next time you use it.
Good luck,
Bill
