Beosound 9000 shutdown...?
Hi all! I have just a recent problem with my Beosound 9000 with it's vertical stand. Last week everything was working pefectly.
Since yesterday when I turned my BS on, nothing's happens, except the yellow light on the first CD, and the red light of this first CD turn on (instead of the standby one). But that's all!
CD doesn't mount and rotate. I use manually the button on the side for the second CD, nothing happens. With the button "Open": nothing!
I use the Beo4 for "Radio": nothing on the display, only the first red CD light.
In the bathroom, when I now choose "Radio": no sound, and nothing happens too on the BS9000 except the light...
Is it a big problem, doctor ? My 6 CD's are in jail...! 🙁
Thanks for any advice
Typical psu faillure.
Mk1 and mk2 are not supported anymore by B&O. So some of them end up with me for fixing the psu's and/or lasers.
So, I hope you have a mk3 version.
However, you can lift the glassdoor by using some force. That way you can take your cd's. Only the one in the mechanisme can't be taken out.
Thanks for answering Beobuddy,
Maybe as a newbee: what is the "psu" ?
I have this model:
link
it is mk3 and psu is a power supply unit (as far as i know....)
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Ralf
OK, it means it could be possible to contact a B&O reseller to repair my BS9000 ?
If you have a reseller or someone you know who can do this type of work.
Otherwise use a B and O dealer who will have a repair facility.
OK i will go to the next B&O dealer, we still have one in the region (2 have dissapeared..)
Thanks a lot all! 🙂
Hello!
Have you already tried to unplug your BS? It's worth a try!
Best regards Elamr
Not at all. But you're right, I should. I try at once!
f5434964 wrote:
Hello!
Best regards Elmar
It works! Thanks a lot 😳
PS: why don't we found in the B&O user manual a "troubleshooting" page..? 😕
You may give me your adress, and I'll send you a bottle of good swiss wine (red or white?) Gift
