Beosound 9000 problems
Thanks for all the interesting comments. I'm going back to B&O tomorrow to see what they say. Fingers crossed this will be sorted 🙂
Hi there....
Just a thought as you may already have checked this. Have you correctly set the positioning tabs on the machine to correspond with its placement - ie vertical or horizontal? I know that this can have an effect especially if the machine is set for horizontal setting but standing vertically.
You would have been supplied with a red key to make the adjustments to the machine.
Regards...
Thanks for the advice but the positioning is correct. I spoke to B&O today and they are at a complete loss and they've told me there is nothing more they can do. As the unit is still under guarantee it looks like it may have to go back and I get a refund - I'm gutted
i think you should think about calling ghostbusters!
Hard luck.
