Hi all,
i have a problem since a week:
I have a Beosound 9000 MKI with Beolab 8000 and Beolab 11 connected.
When I press any audio source the 9000 turns on, the beolabs turns on (green led) but i cannot hear anything. No sound. Same with N.Music and N.Radio, using a Beoplay A6 via Beolink converter NL/ML.
I have the BeoremoteOne BT in Beo4 audio mode.
The converter is configuerd as audio source.
I resetted everything, took the Beosound 9000 more than 12 hours off from mains, but no chance to get it working. This configuartaion worked now since many years.
I disconnected the ML and changed the Powerlink connections and switched the Beoalab position switch.
CD Player works ok. I programmed product option once more to 1. The headphone jack is silent as well
Are there any suggestions what I can check next?. May be faulty sound board?
Hope you can help.
Ralf
