First, my main problem. I just picked up a first generation Beosound 9000. The system works, but it will not respond to my Beo4 or Link 1000. I think I have tried setting the option correctly, but it is almost like the remote is turned off. I know for a fact that it was previously used in a multi-room system using a masterlink setup.
Any help.
Additional information. When I got the system the glass door was down so far it was on the clamper. I rigged a bumper to keep it from closing all the way. Any way for me to readjust it?
One more - the cd gets hit by the sled or clamper. I have "centered" the CD drive mechanism properly, and improperly and it makes no dif. Is the clamper hitting or the sled? How do I know and can I adjust?
Thanks all.
