BeoSound 9000 MKIII CD Scraping Noises On Vertical Floor Stand
I just pulled out my MKI that's setup for the floor stand (both the BS9000 and the stand are boxed now) and sadly it doesn't have the alt cover you're looking for. If it did I'd gladly send it to you. My MKIII is set up for the horizontal table stand and it also does not have that cover. I've checked my other MKI as well, and no luck there either.
As far as spare parts go, I used to buy from my local B&O store. Now that they are gone I've had luck with an eBay seller from Turkey ( the bay userid is link).  Where are you located?
lapaulo7
lapaulo7
Bill Briscoe wrote:
lapaulo7
lapaulo7
Hi Bill,
Thanks for checking and for the generous offer! You have quite a few 9000's! Apparently, this alternate rear cover is rare and only came with the floor stand. All of the 9000's with floor stand listings I've come across are missing the rear cover. I have the standard detachable rear cover but I'd like to keep it intact. The alternate rear cover is the final piece to my setup along with the original MKIII manual and the center glass styrofoam (I am a completist). The search continues!
I am located in New York. I'll keep an eye out on lapaulo7. Thanks for the recommendation. Hopefully something pops up.
By the way, what speakers do you have hooked up to your MKIII?
Thanks again!
I'm using BL8000s in my setup. I didn't fully understand your sentence about completing your setup. Do you still need the center glass styrofoam and the manual? If so, DM me and I may be able to help out.
Dear sir where did you bought the rocker arm 9121 2854207 please kindly let me know my email address sam97can@yahoo.com
Sam
Sam
