bigbruggsy wrote:
Thats great news. As I now have adjusted the APS (the clear plastic cover thing) so its not scraping the cds, but its soooooooooo close to the glass now. And I still have the cd spinning backwards and the pause error. So I guess maybe a new cd laser lens?
The top of the sledge should be paralell with the aluplate. If you need to adjust it waay up, something is wrong.
1. Did you remember to press the black plastic part for the clamper arm, correct back into its place ? If this is not correct, this will cause the APS part to sit to low.
2. I have seen a unit where the APS part was warped/bend. I took it out and heated it up with a hairdryer, and carefully bend it back again. That removed the scraping from that unit.
3. Are the laser assembly correct installed in the holder ? if this is not correct, it will also cause the disc to sit to high, and hit the APS disk holder thingy,
Something is not correct assembled in your unit, that is my guess.
Regarding the pause of cd. It needs a new laser.
And for further testing in the future, if you remove the glass, then open the glassdoor before selecting cd as Source. When the glass is removed, the sledge will not operate unless the lidt is "opened", Once the unit thinks the glass is opened, the sledge are allowed to move, but only slow.
Be carefull to always select cd position 1 before setting the unit into std.by without lid, since this causes the lid to close, and the sledge cannot return since the glass is not there.
/Weebyx
