I checked and cleared the codes. There were no recent codes that I did not expect - CD Error 2 and Sledge Error 39 (this probably from when Testmode 71 finished at position 3 and went into standby.
Some good progress though.
I ran TM 67 a number of times to see if I could match CD Error 2, 3 and 7 to particular behaviour.
By chance I noted that once the CD ran continuously and more quietly, still more noise than I would expect, and it turned out to be playing properly, with good sound on the headphones.
After a few minutes, I tried to play another CD and it started at the third attempt. I left it to play the whole way time. It ran much quieter also.
I also got it to play a CD a third time - this one stopped after about 15 minutes.
If this was not a very complicated B&O system that I do not know well, I'd think that the CD drive mechanism was dirty from being stored somewhere dusty for a long time and that it needed cleaning and lubricating, However I do not know this mechanism or the electronic controls.
Sometimes when I select play, it starts to turn very slowly one way then another, just 1/4 of a turn. Sometimes it spins about normal speed one way then the other very fast and sometimes it does not turn at all.
Make sure that when you change to a different cd you open the glasdoor. It resets the TOC which is stored every time you change from cd.
