Beosound 9000 Issues
cij28 wrote:
When in TM72 I powered off and the sledge dropped to the bottom itself
Hmm, ok, maybe gravity helps here. Usually all repair work is done with the unit on table and cd setup for horisontal position.
But does the sledge move back to pos 1 by itself when powering on ? If so, this is not a problem.
/Weebyx
You need to select CD first, then 72.
Please double check your manual for the centering spring adjustment. For option B, which references figures 1 and 3, the vertical setups, the arrows point to the right.
Hi Dave,
Sorry I didn't know you still have the unit mounted in the floor stand. Arrows pointing "up" in that case is correct. Trying to clean the lens with the unit on the stand will be difficult.
You should try to see what error codes are stored - this is Test Mode 27. Write down any errors that are shown. You toggle between sections using GO, and the up down arrows to move among error codes within a section. When you get to the end press GO to clear all the codes.
Now, run though the CD Test Modes 61-68 one at a time and see which one throws an error code.
Here are the CD error codes with descriptions:
CD: CD error.
- 02: Focus error
The CD could not focus within the time limit.
- 03: Radial error
Set when the CD did not get on track after several retries.
- 04: Turntable motor error
Set when the disc did not spin up or down within the time limit.
- 05: PLL lock error
Set when PLL is out of lock during tracking mode.
- 06: Jump error
Set when a seek could not be performed or an error occured during a binary search.
- 07: Subcode error
Set when a subcode could not be read within the time limit.
- 08: TOC read error
Set when the TOC could not be read, no access possible to lead-in.
Ok the 9000 is now with B&O on the workbench.
Control Panel is now working fine - thanks
CD Deck/Laser needs replacing at £400.
An ex B&O engineer offered to do it for £300 but given the small difference didn’t feel it was worth it.
Thanks all for your guidance we got one issue fixed and the other one should be sorted soon enough.
