cij28 wrote:
Ok TM72 works I powered off and sledge dropped to the bottom of machine.
How do I then access the laser as the sledge disc bit doesn’t open if that makes sense?
Dave
You need to just get the cuetip in under the disc from the right sideYou should see the lasert. You can run testmode 65 which will move the laser all the way to the right, that gets is easier to clean.
So, put the sledge back in position 1, power the unit on, enter testmode, press CD, press 65(laser should move to the right, press 72 to release sledge, and power off and move sledge.
When moving the sledge manually, do it slowly, dont do it with a lot of force.
When you say that the sledge dropped, did it drop by itself, or did you move manually ?
/Weebyx
