Hi, I am trying to remove the gearbox of my beosound 9000 mk2 and am following the service manual for mk3. It says “carry out the points 1-5” which I have done. However it looks like the 4th screw is located underneath the top plate. Has anyone been able to remove the gearbox without removing the top plate?
Beosound 9000 gearbox removal
I have removed the gearbox without removing the top plate. I don't recall how exactly, so I can't say if it was easy or not. I acquired a MK3 that had been dropped and shattered the glass. I had to carry out points 1-5, remove the bottom cover, remove the cd mechanism, and remove the gearbox in order to clean out all of the shards of glass and get it working again. I did not remove the top plate.
The gear box had a few shards of glass stuck between the teeth of the gears and had to be partially disassembled to be thoroughly cleaned.
Im sorry I don't recall exactly how I removed it but I don't recall it being unusually difficult.
Thanks for the reply Bill. I found the 4th screw under some wires and it is indeed reachable without taking off the front plate.
