Does the wall mount simply mount on the floor stand?
I'm looking at a second hand floor stand and trying to get it figured out exactly how to mount the 9000 on it.
I have the vertical wall mount currently.
MJM
MJM
Discard all items from the wall bracket as none of them are required.
You will need 4 set screws with purpose designed trumpet shaped pieces which screw into the back of the 9000 and which fit into the cutouts on the stand. Without these pieces you will not succeed.
*edit*
Just noticed that you are a silver member. Details of the stand and the mounting details are in the service manual on this site!!
Hi, i have just purchaced a floor stand, found it easy to connect the 9000 to, and in my opinion the 9000 looks alot beteer on the floor stand than on the wall. Don't know how you feel about this.
