Beosound 9000 entering test mode with Beo4 ?
Hi to all, does anybody know how i can run the Test Mode of a Beosound 9000 MKI via the Beo4. I am Silver Member, but i just found the Manual for MKIII.
The "trick" mentioned in the forums of using SHIFT 9-0-2-5-8 does not function.
 I am keen to be able to do this as at the moment i have a cd mechanism that moves to the discs , clicks a few times and then goes to pause before switching off (CD does not spin)
Thank you for helping
Phil
anyone ?
It always works for me!
However, either plug powerlink speakers in OR reset to Option 1 every time you switch the 9000 on. The 9000 will default to Option 0 if there are no speakers plugged in and will ignore commands from the remote.
It is a lot easier with a Beolink 1000!!
If cleaning the laser lens does not cure your problem then you need a replacement CD mechanism.
