Beosound 9000 connection to Beomaster 8000?
Iv trued searching, but I can’t seem to find any solutions of connecting a Beosound 9000 CD player, to a Beomaster 8000 amp.
The Beosound has a digital and Powerlink out.
Maybe a digital to RCA converter? I believe the Beomaster 8000 has RCA in.
Or is there a powerlink to Din cable?
Beosound has also DIN out so you can connect it to Beomaster via DIN-RCA cable
Hi Howzit,
Which speakers are you using and which product are they connected to please?  Do you have other rooms connected to the 9000 by Masterlink, or a TV in the same room please?  Are both products in the same room (ie. within remote control range)?
This will help us to understand the best way to get everything connected, so that we can give you the best advice.
Kind regards, Steve.
