beosound 9000 can any one help my cd mechanism is not working correctly, it goes to move then stops and after around 20 seconds goes to disc selected and message comes up cleaning required it plays disc fine.
beosound 9000 cd carriage going slow
A Very Warm Welcome to Beoworld..
When you get this type of problem you need to check the easy things first. This can just be dirt on one of the two sensors, left and right behind the glass door on the base plate and also clean the glass door inside and check again.
As a safety measure the two sensors are used in case your hands are near which slows the carriage down.
Hi
if you raise the glass cover then clean the two clear plastic stems sticking up at each end of the 9000 the cd mechanism should work as normal
G
hi thanks for help but tried what you suggested but same happened, any other ideas? regards wayne
