BeoSound 6 MP3 player - a look inside
We all know how Beosound 6 look outside,- its typical Bang and Olufsen
link
As some us know, BeoSound 6 is  based on a Samsung player called YPZ5
Therefore lets open the player, and take a rare look inside :
link
Go deeper inside the Samsung  player, and read  review and see more inside photos here:
http://www.anythingbutipod.com/archives/2006/03/samsung-ypz5-review.php
How can something designed by Samsung, be defined as typical Beo?
It's awful.
It`s not designed by Samsung but B&O! But manufactured by Samsung.
Honestly,- BeoSound 6 look,  feels and worked as a pure B&O
The pictures tells everything..
link
Read review here http://www.designscout.dk/sophisticated-sounds-from-bo/
At the time was this specific Samsung player knows for the best mp3 sound on the marked (and Samsung are still i front )
Olso notice, that the software in BeoSound 6  is  made by B&O and it  have a much smaller and more simple menu, then the original Samsung player
For normal and simple use its a great player, but today, compared to others, will a mp3 player to 50 -100$ $ could do the same or more.
 But the easy daily use, B&O design, high (steel) quality and best sound - thats still pure B&O, and therefore its still a great player - olso today..
The price today is proberly to high, ask the dealer for a better price...
Bulgarien, I don't share your opinion. The BS6 might not be a bad player, but if you compare it to other brand's products, the quality doesn't match the price, which is not normal for a B&O product.
Then you can say the same about all new BeoVison...I think the panels  come from Samsung or Pioneer and I cant see the B&O design anywhere, they just look like others flat screens.😕
I'm sorry, i don't mean to be rude, but are you delusional?
