Beosound 5 Volume adjustment
Have you connected any speakers to it yet? I had the same issue with mine, but it turned out, that it will only show the sound menu and allow you to adjust the volume once you connect a speaker to it.
/Dennis
That must be it. Thanks!Have you connected any speakers to it yet? I had the same issue with mine, but it turned out, that it will only show the sound menu and allow you to adjust the volume once you connect a speaker to it. /Dennis
Had this with several BS5's. It is a software issue.
After a recovery it will work for sure.
During booting you get the for recovery. Or via the servicemenu you can perform that. Music library and mots will be saved.
When rebooting it says Beomaster 5 and Beomaster 5 Recovery. It says use up down arrows to select one. I can not get it to change from Beomaster 5 to Beomaster 5 Recovery. Perhaps that means there is a problem with it? Or am I doing something wrong? Nothing happens when I press the arrows.During booting you get the for recovery. Or via the servicemenu you can perform that. Music library and mots will be saved.
Hello,
I think you can't use the arrow keys on the beosound 5.
It should work with any USB Keyboard conneted to one of the two USB Ports at the backpanel of the BM5 Unit.
Thanks. Won’t know if that will work very soon. BS5 is wall mounted with BM5 on another floor of the house hidden away, so not very easy to do.Hello, I think you can't use the arrow keys on the beosound 5. It should work with any USB Keyboard conneted to one of the two USB Ports at the backpanel of the BM5 Unit. Ralph-Marcus
You can connect a monitor to the BM5 Unit.
There's an unused DVI-I connector at the rear of the BM5. Just plug the monitor in, add a keyborad to one of the rear USB connectors of the BM5 and restart the BM5/BS5. right after the B&O logo it will show the Beomaster 5 Boot and Beomaster 5 recovery option for about 5 seconds.
