marexy wrote:
I have a weird example of a bug on Beosound 5
After the factory restore, I can no longer update SW.
It says I can't update SW because there is no connection to the server.
Going into the settings shows me no internet connection.
N-RADIO working and finds many stations, but without logos.
What's the problem?
It is "standard" that settings will show "no connection", this is something you can ignore, if it can load the radio stations, then you have internet connection. The logos takes a long time(days) to be completely loaded, and I have also seen there are some XML problems in the log files. Some time ago, other people also talked about the update server not being available, but it was active again after some days. Maybe B&O have decided to shut down the server again ?
It is understandable that they discontinue products, but a "internet product" like BM5, must not have problems with SW update and stations afterwards. It costs a lot of money, and should be expected to continue to have access to backend for a very very long time in my opinion. It cannot cost B&O that much money to have that backen running.
My fear is that they have no people, that knows anything about those servers anymore. Which is kind of worse.
Keep the BM5 running for some days, and see if radio covers appear over time, and keep trying the SW update.
/Weebyx
