Beosound 5 St.by off-on problem
Hi
Did any of you have the same problem?
I have a BS5 that works fairly normally.
BS5 turns on normally. It works everything...ok maybe it is taking some more time for booting.
However, when I turn it off and the unit goes into st-by, i can turn it on with beo4 after 5 minutes...but.. after 20 minutes or more I can no longer switch it on wirh the remote control.
I can only turn it on on the BS5 keyboard.
strange .. :(
marexy wrote:
Hi
Did any of you have the same problem? I have a BS5 that works fairly normally. BS5 turns on normally. It works everything...ok maybe it is taking some more time for booting. However, when I turn it off and the unit goes into st-by, i can turn it on with beo4 after 5 minutes...but.. after 20 minutes or more I can no longer switch it on wirh the remote control. I can only turn it on on the BS5 keyboard.
strange .. :(
Switch off Eco option
Thanks for answer :)
What is Eco option ?
Where can i see that in menu ?
Is that automatic st-by ?
