BeoSound 5 Encore to BeoLab 5 Connection Help (Non B&O Amp)
Since the encore is a standalone system by definition, even adding a BS4 would bring you back to the same problem of jumping through hoops. There isn't a convent way of doing what you are asking with the current equipment.
If it simply means changing the "source" on the BS4, then that's perfectly fine! I just want a more convenient way of using the BS5 encore in my current setup, without changing the "option" of the BeoLab 5's each time..
Reading the comments above and with your current equipment it sounds like you need to compromise on convenience or quality, as it's clear it's not possible to do both without new toys.
So with no new kit, the convenient thing would be encore to amp to speakers, but as you say may not give quite the same quality (although I'd be surprised if much different), or go the sound quality approach but means you have to switch it over each time.
Get yourself an Avant!  Sorted!!
I've covered the sound quality issue difference in an older thread here - /forum/general-discussion-and-questions/bampo-in-white#post-1831200
Avant would be perfect, but not the best, financially.
If I got the amp, I think I could go:
Encore directly to BL5 speakers (The BeoLab 5 speakers have 2 Powerlink inputs)
And the BeoSystem 4 Amp to the BL5 speakers, BL3 rears, and BL 7-2 center, all via Powerlink.
But then i'd be unable to upgrade my TV to 4K using the BeoSystem 4...
So Avant is probably the best choice in this instance for best sound quality etc..
Hmmm..
