plbouquet wrote:
the beosound came back to "life" : I can see my music, go through it with the wheels , change from music to radio with the remote but there are still some ( major ) issues:
- there is no sound comming either from the speakers or from the headset
-I cannot shuffle through my music with the remote ( although I can shuffle through the music with the wheel and I can shuffle through the favorite radio stations with the remote)
maybe I replaced one of the connectors incorrectly ?
Okay, great that it worked for you. At lease your Encore does boot now.
Which speakers have you connected? Do they switch on or will they stay completely in standby mode?
Have you connected your headset for testing to the correct jack? Line-in and HP-out can easily be mixed up...
If everything else does work fine there is only a very little chance that this is due to missing internal connections.
If MOTS calculation is not finished you have to select the whole album to play. Then you can use the arrows on the remote for the next/prev title.
If you select a single song with the wheel and and press GO you cannot go to the next title using the remote if MOTS calculation is not finished.
At least this is the behavior I can remember...
CB wrote:
Don't know if the BS5-E sports a long life battery (to remember the settings for example), but it may be worth checking this...
No there is no battery but a supercap as far as I can remember. This is only for keeping the RTC alive and has nothing to do with settings. Anyway, all the settings and caches will be lost after formatting or replacing the SD card.
