Beosound 5 Encore easy masterlink...
Some people here would be happy to get the long-rumored BeoNet to Beolink module, allowing the BS5 Encore to be connected to a "good old" masterlink setup easily.
I just figured out that maybe we don't have to wait, as the interface allowing to connect a BS5E to a videomaster is already there! 😐
The idea : using the Beolink converter (1611?), designed to adapt non-Beolink capable audiosystems such as the Beosound 2300 to Masterlink videomasters.
It should allow to connect a BS5E to a Beovision via Masterlink in audio mode, and to distribute the sound in link rooms... Am I wrong?
Unfortunately yes this will not work as the Encore currently has no connectivity at all for multiroom systems.
According to my B&O dealer the products of this company:
A Beosound 2300 only has Powerlink.
A Beosound 5 Encore only has Powerlink (and has BeoNet for the future, but that's another thing)
With a Beolink converter (1611), I can connect (and use in linkrooms) the radio/CD from my BS2300 to a Beovision used as master.
Why couldn't I do the same with the Encore and the BS2300? (I know you're a store manager, so you may be  answering that to preserve sales of "normal" BS5 in "masterlinked homes", but you can say the truth, no one is listening here 😐!!)
Mbee, you're confusing your ports. The BeoSound 2300 works using the Datalink socket (which looks very much like a powerlink socket) for MCL transmission. It's the precursor to the BeoLink.
It's the exact opposite. As store managers and salespeople we would love to be able to integrate the BeoSound 5 Encore, but it is not currently possible.
Ok, I didn't know that the Beolink converter was using datalink... So... No hope! [:'(]
The only thing you can do, if you already have a video setup with all your speakers connected to it, is connect your BS5 Encore Powerlink out to your front or rear speakers Powerlink sockets on your BeoVision/BeoSystem socket panel; since Powerlink signals are looped, once you turn your Encore on, your front or rear BeoLab speakers from your TV system will turn on as well. I used to do that on my BV3 when I had run out of Masterlink cables and it works 100%; the only thing you'll need is a Powerlink Y splitter, since your socket panel probably has 2 outputs (left & right), and since you probably use them both already..💡
@Chris:
what happens when the Encore and a video source output simultaneously?
TripEnglish wrote:
link
Totally almost pissed into my pants laughing ...  Good one Trip! :-) :-) :-)
