Beosound 5 / Beomaster 5 - Wireless
Just use any wireless access point / repeater with an Ethernet / LAN port. set it up for your wireless network and connect it with a LAN cable to your Beomaster 5 and you're ready to go and you avoid messing around with the Beomaster 5 software.
An Example is the Airport Express or other small access points.
Agree - that would be a better and easier solution.
Orherweise consult this guide - page 32....
Thanks for your help here. I will go down the Wireless Dongle route. If that fails will try an Airport Express
