Beosound 5 / Beomaster 5 - Wireless
Anybody with a Beosound 5 / Beomaster 5 setup able to make a Wifi connection as a opposed to a Wired connection. If so would they be kind enough to share their solution
Thanks Nigel
Do you mean using wireless to BM5 instead of a cable?
I have mine wired to an airport express.  Works great.
I found a wireless USB dongle many years ago, but it is hard to find one today with drivers for WindowsXP today.
Yes correct, I currently use an Ethernet cable.
The Sandberg wifi dongles does usully have XP support and no need for extra drivers.
https://sandberg.world/sv-se/product/Micro-WiFi-USB-Dongle
I now have obtained a compatible wireless dongle how do I add it to my network
You have to start the BS5 service menu and enter windows xp and connect it to your network
Thanks I presume you need a keyboard/ mouse
Yes that is correct. There is USB in the back of BM5
