Beosound 4 sticky plastic
Hey
Just got a Beosound 4 from 2007.
The soft plastic is sticky .
I have asked some that say it can not be "cleaned" but need new paint , but just want to ask here also.
Have anyyone tried to repair the plastic on BS 4 ?
Anders
You can wipe it all clean of dust and dirt and spray it with satin black (or matt black) automotive paint - but it's nothing like original. It will just seal in the sticky and create a new, non-sticky surface.
I recommend this :
Hi Lee
Ok thank you.
But will I not also be spraying into the eletronic  ? Top and button there I se einto the eletronic
br
anders
anders92240 wrote:
But will I not also be spraying into the eletronic  ? Top and button there I see into the electronic
Apologies - I assumed you'd be stripping it down to do any refurb work...
In which case, I have no suggestions apart from a new casing fitted by an approved B&O Service Center.
Other methods may work, but I've never found any (not to say there aren't any!_
Those "soft-touch" surfaces are one of the worst inventions in recent time 😡 -like using "foam-rings" in speaker units instead of rubber... 😕
But the decomposition of the surface seems to be dependent on the environment in which it has been stored (humidity etc.).
I have bought two (secondhand) Beocenter 2 systems. On one of them, the socket-box was fine -on the other it was sticky.
I spray painted the surfaces with matte black paint. But offcourse you'll have to take it apart - or cover the parts that shall not be painted, with plastic/tape.
hi
this surface is poorly thought out decision of many manufacturers who think it lasts more than 10 years.
If the unit is in the sun, it will not last for 5 years :(
as thay suggest..it's best if you stip it total...so you have only plastic parts..
1. only clean with iysopropanol .
2..spray first with car paint prymer 5x ..sandpaper it to nice to a beautiful flat finish.
3.spray  black matt paint. ..do it from 50cm ,,,5x thin. so you get nice finished surface :)
i do that with BS4 or BL3 or Beosound 2 socket unit
anders92240 wrote:
Hi all
Thank you very much.
I have been offered a New orginal B&O rear cover / chassis for 73 euro.
Sounds like a good option if you can fit it easily enough.
Hi again
Just wanted to ask how diffucult you would say it is to take the BS 4 appart so I can clean and paint the rearcover and the frontcover ?
1 to 5 where 5 is very diffucult ? ( for someone that usually dont do somethink like this )
I did found the PDF for BS 4 service manual that show how to take it appart
Anders
It's 2-3 out of 5.
