During a move and subsequent re-installation of a BeoSound 4 system, I decided to make some additions to the setup so that it fits better with my "modern media" setup.
Specifically, I connected the TV to the system so I can enjoy the sound of my Beolab 4 speakers for movies.
Furthermore I purchased a special cable (
BeoSound 4: Noise when using RCA and Masterlink Inputs
Note:
Steve knows this, since he originally made the cable.
If you want both devices connected in a fairly easy way, you could use an AUX-expander to switch manually between both.
There are several to have - maybe Steve (SoundsHeavenly) can provide one?
Thanks MM,
Yes, here is an example of a suitable Aux Expander box to allow up to 4 devices to share the Aux In sockets of the Beosound:-
Thank you Steve - guess I was too fast to get that Masterlink to Minijack cable. I'll give that Aux Expander a look.
