All:
I have Beosound 4 shutting off after may be 3hrs of operation. I thought the fix would be to access the customer service menu and set it to OFF mode.
However, when i got into the service menu I cannot find the Autoshut off as an item in the list.
I used the 00 GO option from the setup to access the service menu.
Is there a way to fix this problem. Or is there a fault with my system. One more thing I may have to point out is I have a beosystem 4500 connected to Beosound 4 via the AUX
Thanks for any helo
