Beosound 35 and Beo4 ?!?
Strange indeed !
The last update was June 13
Version 1.17.23091.157086471
So, it was updated recently...
An other possibility is that I activated something in the Beo4 without knowing (I was Β« playing Β» with the hidden buttons)
EDIT: this is it !
How do I activate sources using BeoRemote One or Beo4?
To use Beo4, you must set the audio system in A.OPT 1.
β> A.Opt set to 0 solved my problem π(and pressing Radio still starts the BL5)
Have to say that these Beo4 options are not clearly explained...
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
