Beosound 3200 with hard drive. Subwoofer. Masterlink compatibility.
I have a Beosound 3200 with hard drive. I would like to connect a B&O subwoofer via the masterlink socket as the aux socket on my Beosound 3200 is already in use. Could someone please tell me which B&O subwoofers would be compatible, if any?
Thanks.
Use a powerlink socket to connect Beolab 2 or Beolab 11.
Best would be to connect the 2 speakers attached to the Beosound 3200 right now to the subwoofer (so filtering of frequencies is managed by the Sub).
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I’d say none without some tricks.
Steve of Sounds Heavenly probably has one up his sleeves πŸ™‚
I once jury rigged a master link cable to drive some 6000s as an experiment β€” but issues like trigger signal and keeping the subwoofer alive would be beyond me β€” however others on the forum have that expertise.
Another option would be a black box approach. Here the issues might include signal delay in getting the audio signal to transit the ML input > black box processing > PL output.
The black boxes I am thinking of are:
1. An Active kit
2. A BLC NL/ML Converter
3. The predecessor of the Essence (my mind is drawing a blank; MM will know if it can be done as he has one), and finally?
4. One of the Almado boxes ???
kallasr wrote:
You powerlink socket to connect Beolab 2 or Beolab 11.
Ralf
Ralf’s answer is far more sensible.
For example I have a powerlink from my Essence to a BL11 subwoofer and then a daisy chain to two BL6000s.
Note to self: do not answer any BeoWorld questions after πŸ₯‚πŸ₯‚
