I have a Beosound 3200 with hard drive. I would like to connect a B&O subwoofer via the masterlink socket as the aux socket on my Beosound 3200 is already in use. Could someone please tell me which B&O subwoofers would be compatible, if any?
Thanks.
Thanks.
Use a powerlink socket to connect Beolab 2 or Beolab 11.
Best would be to connect the 2 speakers attached to the Beosound 3200 right now to the subwoofer (so filtering of frequencies is managed by the Sub).
Ralf
Ralfβs answer is far more sensible. For example I have a powerlink from my Essence to a BL11 subwoofer and then a daisy chain to two BL6000s. Note to self: do not answer any BeoWorld questions after π₯π₯You powerlink socket to connect Beolab 2 or Beolab 11.Best would be to connect the 2 speakers attached to the Beosound 3200 right now to the subwoofer (so filtering of frequencies is managed by the Sub).Ralf
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
