Hello all in Beoworld. I've tried searching for photos of how the laser should be fitted back in my beosound 3200. I know I should of taken photos before I took it apart, oops.
My issue is how does it fit with the 2 parallel tracks, one side is easy as it goes through the holes, the other side is more tricky as the way I have it installed the cd laser pickup is now on an angle. Please view the photo I've taken and hopefully either one of you will be able to tell me if I've installed it correctly or the replacement cd laser I was sent is not the correct one.
this is the part I used
Thanks all.
