The correct aerial fittings on my Beosound 3200 are missing. I have looked on Ebay & the fittings that are present are
TV/FM COAXIAL CABLE CONNECTOR FEMALE PLUG
I tried fitting a standard
COAX FEMALE SOCKET TO F PLUG ADAPTOR CONNECTOR CONVERTER SATELLITE
but this is too big for the socket. The part for the fitting to push in to is present.
Can someone please tell me which type of aerial fittings I need?
Thanks.
