BeoSound 3000 with BeoLab 3500
Good evening
I am so sorry if this has been discussed and solved before, but I cannot seem to get the other guides to work.
I have a BeoSound 3000 mk1, a BeoLab 3500 (old one with MCL) and a Beo4 remote.
They are playing in the same room, but I cannot control the volume with the remote. The Beosound 3000 is set to A.OPT 1. Is it possible to use the same Beo4 to control the 3500`s?
Best regards Kristian L
MokiPhone wrote:
Good evening
Hi Kristian
The 3000 needs to be in A.OPT 0 and the 3500 in L.OPT 6.
Regards
Stuart
Thank you Stuart. Do you know if I can use the same remote to program both the BS3000 and the BL3500?
