Beosound 3000 option selection fault
Hi
*****Please ignore...........I figured it out!!!****
I am trying to change the option setting on my Beosound 3000 but it seems like its not changing.
I have tried using a Beo4 and  beolink 1000. Is there any indication on the Beosound 3000 when the option has been changed? The Beosound 3000 works perfectly otherwise.
I am definitely using the right procedure when trying to change the option so its not that! Perhaps its faulty?
Ben
Hi
If the BeoSound 3000 receives the option programme command, the red LED should blink once.
Opman
