Beosound 3000 and BeoVision 7-32 masterlink
Hi all, first post, lurking so far.
I have tried getting a basic setup going using the bs3000 and a bv7-32 with masterlink. No speakers attached to the bs3000, beolab 7-1 on the bv. I think I’ve tried all combinations that make sense with regards to option programming. I simply can’t get sound from the bs to play on the bv! Sound from eg tv or dtv play fine, so the bv and bl are good. The bs can play from cd, radio or aux when stand alone with speakers attached, so it’s good too. When linked with masterlink, when I select a source from the bs, eg cd, the tv seems to switch to the correct source (indicated on the led display) and the cd starts playing on the bs. But no sound. Same for all sources.
can anyone give me some pointers? I’m at a real loss here...
TIA
Thanks for the suggestions. I just tried what you proposed, same result. Cd starts playing, I can switch tracks, but no sound. I programmed the options again like you said, and tried reversing the cable. This cable has been used successfully to connect the bv to a beolink 3500 previously. Anything else I can try?
Great news. Thanks for letting us know the solution as that may be very helpful for those with a similar problem in the future. 😄
