I have just inherited a Beosound 3000 with the most basic of the B&O remotes - no screen. I can't get any sound out (except by plugging headphones into main unit - so that is working!). This is a stand alone system with B&O 35 Passive Speakers. There is a MAsterlink cable in back of CD unit, that then splits into two - one goes into the power/distribution unit and the other is free? I have tried swapping these around but no help. I did read somewhere about setting Option 1, but handset has no sound button (SOUND, 1, STORE) and does not work if I try this on the CD unit? Ideas anyone? Thanks.
Beosound 3000
Good morning, Merry Xmas and Welcome to Beoworld - what do you fly??
The Beosound 3000 would normally need active 'Beolab' speakers so that could be your problem, or is the 'Power/Distribution' unit that you mention an amplifier? What do the labels say?
I think we may need more details before we can assist!
I have the MCL2P
Jeremy
Hi Jeremy,
In that case you need a PowerLink cable (8 pin DIN at each end) from one of the two Powerlink sockets in the centre of the BS3000 socket panel. This connects to the Powerlink input socket on the MCL2P.
Of course you also need speaker cables and a power cable attached to the MCL2P. The MCL2P should then switch on (you hear an audible click) when you switch on the BS3000.
You should not need a Mastelink cable (this has bespoke B&O rectanular plugs at each end, and would usually be used if you are routing the audio to another room).
I hope this works!
Guy
