I've had my Beosound 3 on charge for weeks but haven't used it. Now it won't turn on. Is there a way to re-boot it without opening it or sending to B&O for repairs?
Beosound 3 died
Dependent on how old it is, the silver foil membrane under the keypad on early models required replacement, often leading people to believe their Beosound 3 had died. 3 weeks charge is a bit excessive but should be ok.
Thanks.
Is there a problem leaving it on mains power? I always have it plugged in to keep it charged up....
Heya you can keep it plugged. Nothing bad about it.
I had the same problem with mine and got it repaired under warranty. As the previous poster mentioned there is a known fault with the ealrier models. I also find at times that I get electric shocks when unplugging it from charging. It is currently with the dealer again to check over the PSU. Has anyone else encountered this?
Simon.
