Hi All,
Long time no post ... life takes over!
I wondered if anyone here has a Beosound 3 (portable FM radio) that has died due to either a faulty top plate (common) or perhaps a broken speaker.
Because my much used and loved Beosound 3 found itself sitting in about 5mm of water last week - and the bottom PCB has fried.
Parts no longer supplied, so looking to cannibalise one with a knackered top plate.
My own BS3 top plate only works partially - but as it is, in effect, a one room, one volume radio that didn't go anywhere, we only use the on/off function, which still works!!
If not, it will probably be replaced with an echo dot.
Cheers,
David.
