The battery of my BeoSound 3 needs to be replaced (circa 15 minutes at moderate level).
The touch panel, the antenna and the loudspeaker are fine.
A dealer charge me 150€, it's too expensive!
Do you know if :
- I can find an equivalent battery model?
- Can i change the battery myself? I didn't find any instructions on BeoWorld or on the net.
