Beosound 2 and Spotify Connect
Just bought a Beosound 2 mk2, and I cannot spot Spotify Connect in my list of cast options. Only Google Cast appears, which I don’t want to use.
Compare it to my beoplay M5 which works like a charm with Spotify Connect.
Has true Spotify Connect disappeared for Beosound 2?
[View:https://photos.app.goo.gl/SBMGN4sCV2rytegy5:800:0]
Are you sure that you have configured the device to use Spotify Connect?
Hi. How do I do that. I am not familiar wirh any devices have to be setup specifically for Spotify connect. If they are on the network, and I have.A premium account, then it should work.
As far as I know the BS2 Mk2 has support for Spotify Connect.....but I don’t have one here to test it.
Please look for something similar to this (from my Essence 2nd gen) - see screenshot.
The benefit of ‘integrating’ Spotify this way is, that you can redistribute Spotify using Beolink - however, only to B&O devices that already have support for Spotify Connect.
I use it to play from my Essence and to join-in on my BV Avant/2014 and the V1-32.
You should put in your Spotify Premium credentials there:
No sign of Spotify under configuration, so it is gone.
Hi Michael..
Did you find a solution to this? One idea I thought could work was to start a Spotify Connect session on your M5, and then join on your BeoSound 2? I do this to play music on my BeoSystem 4 based TV and works perfectly - my TV remote changes the Spotify tracks. I mute the speaker where I start the stream. A tad clunky, but it works.
I would like add  another BeoSound2 for my office/gym situation but Spotify connect is a bit of a non-negotiable for me, especially as I am trying to de-google my life!
I wonder if I need to wait for a MKIII BeoSound 2 with the new platform.
Having just worked through a purchasing decision between BS1 and Level, B&O sure doesn't make it easy.  Just when you think they've given up on Spotify and are going all in with Deezer, they release the Balance and Level which don't support Deezer, and only support Spotify, but no NL (so Spotify Connect doesn't really matter that much to me as I want Spotify Connect so my devices can "join" Spotify streams over NL).  All in with GVA?  Nope, A1 now does Alexa.  At least they've standardized on TuneIn.  Nope, Level/Balance does B&O Radio instead.  What a mess.
I think their plan was to go all in with GVA (and they may have even said this at one point) so, if you're using GVA as the primary interface, then built-in streaming services and NL do not really add much.  You just say "Hey Google", and Chromecast figures it out, and it also handles multi-room.  I'm sure there is licensing associated with including built-in services so why pay for that (and all those engineers working on NL) when Google will do it.  Another strike against NL is that Chromecast and NL don't get along well (if you're playing something via CC, you can't distribute it via NL).  Why confuse customers?  Get rid of NL and everyone will be happy with GVA/CC.
However, corporate plans don't always match what customer want.  Enough customers said NO to Google so B&O had to pivot.  With all the recent Chromecast problems, maybe (I'm optimistic) they've learned that putting all their eggs in the Chromecast basket isn't a great long term strategy as you're at the mercy of a vendor who doesn't necessarily care whether their choices ruin your business.  Now, they're bringing back Spotify (see Balance and Level) and dumping TuneIn because who needs it when you've had your own internet radio service for DECADES so you're no longer at the mercy of TuneIn to keep popular stations on their platform.  One question, though, is when (if) the Balance/Level get NL, will they be able to play TuneIn sourced from older devices, and will older devices be able to "Join" B&O Radio?
So, it is a mess, and it makes it difficult for those of us with existing equipment to easily add something new.  I finally chose the BS1 GVA over the Level because it fit the space in my kitchen better, sounded almost as good, was cheaper and supported NL today.  Every device I have supports Deezer so I can do multi-room with that (or CC + Spotify... when CC works, which lately has been very sporatic).  Had the Level supported NL, I probably would not have even looked at the BS1.  I just hope I don't miss Spotify too much.  They seem to do better at creating playlists that can be distributed via NL, but I will give Deezer a chance (so far, the Deezer playlist I can see in the B&O app are pretty generic).
This doesn't work.  When you go into the "multi-room" page in the B&O app, if you're playing spotify, it only shows other devices that have spotify connect built in.  At least this is how it works with my BS2 (mk1 - with Spotify Connect) and BS1 GVA (no Spotify Connect).   If you press the "join" button on the BS1, it "joins" (the B&O app shows the two rectangles by the device), but it doesn't play anything, nor does it show up in the list of joined devices on the multi-room page.  You probably get away with it in your setup because the BeoSystem 4 doesn't tell the network it's playing Spotify (which the M5 will).
