Does anyone have info on where to get the supplimentary guide??
Thanks.
A warm welcome to Beoworld..
I have had a look at this "Supplimentary Guide" and whilst it is 8 pages in size, it is just four short paragraphs repeated in all the common languages.
It says:-
The following information supplements page 13 in the Guide.
If you use BeoSound 2 in Mass Storage mode, or load the SD card in a PC card reader, the card must be scanned to update the playlist file.
This scan occurs automatically if no playlist file is found on the SD card when you switch on BeoSound 2.
If the playlist file on the SD card needs to be updated, start the scan by pressing and holding both "Down Arrows" buttons for two seconds. During the scan, BeoSound 2 beeps at three second intervals. When scanning is complete, playback starts automatically.
Switching off BeoSound 2 stops the scan. However, this produces an incomplete playlist file.
I use a card reader and all you need to know is :
1. make sure you have album folders only , not artist then an album folder in that as the beosound only seems to deal with 1 layer of folders.
2. If you are adding or deleting from a card , after finishing delete the playlist file at the root of the card and the beosound automatically refreshes when you switch it on.
I have 4 cards and once they have been scanned once by the beosound they can be swapped around as you like without any rescanning.
Keith,
Thanks for the welcome and the quick response. I was unaware of the needed card scan. However my current problem would appear to be further up stream. When I put a card that I have been using in a Beosound 2 (and which was "loaded" through the Beosound 2 base) into the card reader, it readily recognizes all of the files and file names on the card. I chose to take all the existing files into the trash and then "drag and drop" the new ones from iTunes onto the card. When I do this the new files are all shown to be resident on the card but they all have 0 bytes. Perhaps the card then needs to be scanned by the Beosound 2? I shall try this.
In the process of trying a few things prior to putting up this query, I ended up with a card that the Beosound 2 will no longer recognize even after reformating the card in the Beosound 2. The card does work in my Leica camera. Is there some sort of initialization that needs to be done?
Thanks for the help!
Keith,
I have been traveling and did not get a chance to try the helpful advice you provided. I now have and everything seems to be working fine. The required scan was the problem. Thanks again for the help.
