BeoSound 1 or BeoLab 4 PC
I'm thinking of getting a BeoSound 1 in the near future. I was looking at the BeoLab 4 PC at first, but the BS1 is so much better looking ( although I love those lights on top of BL4s ), has a CD player, alarm clock and I imagine it also sounds much better. So the choice seems kind of obvious. Kind of.
This would be in my small studio apartment and as much as I would love to, anything bigger/louder would just be risking my neighbours kicking me out. I would mostly use it for listening to CDs and also as a speaker for my MacBook Pro ( maybe via AirPort ).
So how much better does the BS1 sound, when comparing it to the BL4 PC? Is the price difference worth it? The BL4 PC is around 800 - 900€ here and the BS1 with a floor stand is 1900 €.
I would love to hear your experience and advice.
PS. I intended to use it with a Beo1, until I found out it only works with BV1 and BC1. How stupid was that? Any idea why they limited it to only those two?
Get the BeoSound 1! You won't be disappointed...
The BeoLab 4s as a package can't touch the BeoSound 1 (which is one of B&O's best products IMO!).
I'd say it sounds better too...
I have a Beosound and until about 2 days ago Beolab 4 PCs in a small apartment. The beosound 1 is by far the best. The Beolab 4 PC are better than most of the reviews on the internet but the beosound just sounds better all round.
Another vote for the Beosound 1 from me!
The BS1 has much better speakers than the BL4 are! Get the BS1!
Beosound 1, and via DIN connector iPod ready.
That was the idea. The only problem I have now ( apart from finding another 1000€ : ) is the stereo sound. You can put BL4s as far apart as you wish, but you're stuck with BS1. Also, the MBP and speakers ( Heybrook 0.5 - can anyone compare the BS1/BL4 to these? ) are on a table in the corner, and the BS1 will be on a floor stand on the other side. I guess I'll have to do some redecorating : )
The BeoSound 1 is stereo. The stereo might be better with BeoLab 4s either end of a room, but the punch and sound of the BeoSound 1 is far superior in my opinion.
BeoSound 1 is also portable sound, so you might want to bare this in mind as a possible advantage. I love picking up my BeoSound 1 and playing it somewhere new.
Get the BeoSound 1.I have one since 5 years and it sounds better than BL4.
