Beosound 1 (old) IR Problem - only works very short range
Hey Guys!
I have a problem with my Beosound 1s IR receiver (I think).
If I operate the Beo4 very close and in a certain angle to the BS1 (aprox. 10-15cm away) it works fine. If the Beo4 is any further away, it does not work.
I have tried a different Beo4, new batteries etc. so I am pretty sure the BS1 is the problem.
See also this thread:  /forum/general-discussion-and-questions/beo4-does-not-work;
The BS1 otherwise works perfectly fine. I changed SMPS power supply a few weeks ago.
I do not see any IR lights on the BS1 through my phone camera.
Does anybody have an idea how to fix this? Preferably without changing the Display/IR PCB for a new one?
Thank you in advance !
Carlo
Can somebody help?
Regards
Carlo
Can somebody help?
Regards
Carlo
I have no real advise other than that you will not see any IR lights on your camera since the BS1 does not transmit anything. The BS1 only receives.
Would this possibly help?
/forum/general-discussion-and-questions/beocom-6000#post-1809306
