Beosound 1 - deactivating the Lamp
Unfortunatly not.
That is the same with almost all the speakers that B&O insist to have a lamp glowing.
Should be a simple thing to introduce a "night mood".
Email B&O and let them know.
Is it possible to disconnect the lamp?Unfortunatly not. That is the same with almost all the speakers that B&O insist to have a lamp glowing. Should be a simple thing to introduce a "night mood". Email B&O and let them know.
On the Beolab 20, Beolab 18 etc the light goes out after a few seconds and only lights up as it turns on or off or is in safe mode. The older models these replaced however always had a light. On a side note. When Apple introduced iMac G5, the first flat iMac (without a globe foot) they got complaints from students because their dorm rooms would be to light with the iMacs sleep pulsating light indicator. Apple responded by a firmware fix that allows the illumination to shine less bright when the room light level is less than in daytime, using the light sensor primarily used (and only for, before) the monitor. 🙂Unfortunatly not. That is the same with almost all the speakers that B&O insist to have a lamp glowing. Should be a simple thing to introduce a "night mood". Email B&O and let them know.
Unfortunatly not.
It is not possible
Should be very simple indeed as they already control the color and the intensityShould be a simple thing to introduce a "night mood".
