Hi
I have strange problem with my Beosoud 1
All is working fine, CD, FM radion, AUX ..
but..there is no clock!
If i go step by step as by the manuals nothihg happened.
Can't se clock on the dispaly.
any suggestion?
Hi
any suggestion?
Nobody have Beosound 1 anymore?
could it be this is MK1?
As far as I remember only MKII had the build-in-clock.
Pressing << and >> in standby leads to what?
AU -> MKI
clock: MKII
(In MKII you have to press CD< and CD> to get AU)
HTH
hx
Thanks guys
Than my is MK1...and no clock....shi..t.
I din not know there are MK1 and MK2
How can i check that?
By type or serial number?
b.r.
Just do what I recommended. .Press << and >> (simultaneous) in Standby.
pretty sure it will display "AU" (=AUX) if it's a MKI
Don't know about type number differences but I think SW2.0 and up is MKII
hx
